AEROMOTIVE AEO18689 PHANTOM 200 UNIVERSAL IN-TANK FUEL SYSTEM
Features- 200 lph high performance fuel pump
- Fuel resistant baffle / basket
- Universal high flow pre-pump filter
- Modular design can be cut to height to fit almost any fuel tank
- Turbine pump mechanism increases durability
Supports- 450 HP EFI Forced Induction
- 600 HP EFI Naturally Aspirated
- 600 HP Carbureted Forced Induction
- 750 HP Carbureted Naturally Aspirated
Specifications- Dimension: 17 x 6 x 6
- Weight: 4.08 lbs
Price: 824.07
