B AND M CO 70297 OIL COOLER LARGE HI TEK COOLING SYSTEM WITH FAN 590 CFM RATING
Hi-Tek Super Coolers are fitted with a high quality 12 Volt electric fans and built in mounting brackets which makes it ideal for maximum cooling. Suitable for many fluids including ATF Engine Oil Differential Oil and power steering fluid.
Features- Fin And Plate Cooler Construction
- Includes 12 Volt High Flow Fan
- Includes Thermal Switch
- Pressure Tested To 200 PSI
- 9-1/2 diameter fan
- 6 Amp capacity
Specifications- Cooler Inlet Size - 1/2 NPT
- Coolor Outlet Size - 1/2 NPT
- Depth - 3.25 in.
- Design Type - Tube and Fin
- Height - 12 in.
- Inlet Attachment Type - Female Threads
- Material - Aluminum
- Outlet Attachment Type - Female Threads
- Package Contents - Cooler and fan assembly
- Width - 13.5 in.
Price: 533.79
