ECI FUEL 5817 20 GALLON REMOTE FILL FUEL SYSTEM
Features- Powder coated black
- Made from 14 gauge aluminized steel
- For use with gasoline not with a blend of more than 15% ethanol.
- Fuel tank with protective cover
- Tethered cap
- Carbon canister
- Mounting brackets (1/2 in. hole)
- All required clamps
- Mechanical sending unit/gauge
- 10 ft x 1/4 in. SAE 30R14 low permeation hose
- 10 ft. x 5/16 in. SAE 30R14 low permeation hose
- Volume - 20 gal (75 l)
- Weight - 73 lbs. (33 kg)
- Tank Dimensions - 7 x 27 x 24 in.
- Overall Dimensions - 7 x 27 x 29.375 in.
Price: 874.35
