FAST-COMPETITION CAMS FST30400-KIT FUEL INJECTION SYSTEM EZ-EFI 2.0 SELF TUNE
The original FAST EZ-EFI changed self tuning fuel injection forever with the industry's easiest carburetor-to-EFI conversion option. Now the EZ-EFI 2.0 has been upgraded with more features than ever before while maintaining its ease of use that doesn't require a laptop or tuning experience. It simply tunes itself as the user drives. Its eight-injector die cast throttle body features late-model OEM sensors for accuracy and durability supports up to 1200 horsepower (the highest on the market) includes ignition timing control and is able to run E85 E98 and E15 ethanol-blend fuels while competing versions cannot.
Features- Higher flowing &higher HP capable 8 injector throttle body that supports up to 1200 HP!
- Updated hand-held features the industry's only multi-color high-tech touch screen display with Garmin GPS-Style suction cup mount
- Market's fewest connection wires with sleek OEM quality wiring harness w/mesh-type loom
- Able to run E85 E98 &E15 ethanol-blend fuels as opposed to competitor versions that cannot
- Compatible with in-line &return or returnless in-tank fuel pumps
- Fuel pulse damper creates extremely precise fuel control that always allows a returnless in-tank pump fuel system to be used.
Price: 4057.24
