FUEL SAFE AUX65FCBRIK 65 GAL FUEL SAFE COMBO INSTALL KIT FOR FORD DODGE 2011-C GM
This is a rectangle 65 gallon diamond plate aluminum diesel auxiliary tank and FUEL SAFE toolbox combo with Fuel Shotz installation kit for Ford Dodge and 2011-Current GM trucks. Our Fuel safe fuel tank/toolbox combos take fuel security to a whole new level.
Features:- The fuel filler and fittings are inside a compartment under the lockable lid of the toolbox.
- This auxiliary tank and install kit meet the necessary DOT requirements.
- This Fuel Shotz system connects the auxiliary tank to the factory tank via the factory fill neck hose.
- This system keeps the factory tank full until the auxiliary tank is empty.
- The Fuel Shotz installation system is quick and easy to install with no wires or switches necessary.
- Large key locking toolbox with storage compartment allows for safe and secure storage of your tools and equipment.
Specifications:- Capacity - 65 Gallon.
- Dimension - 60 x 21 x 19 in.
- Item Weight - 102 lbs.
Price: 1296.30
