FUEL SHOTZ AUX41RIK 41 GAL DIESEL AUXILIARY TANK INSTALL KIT FOR FORD DODGE 2011-C GM
The rectangle aluminum auxiliary tank is the most popular ATI product. The tank provides multiple options for transporting and fueling purposes in regards to diesel fuel.
Features:- Quick easy installation. Rectangle diamond plate aluminum diesel auxiliary tank with Fuel Shotz installation kit for Ford Dodge and 2011-Current GM trucks.
- Tanks are baffled to reduce movement of contents.
- No wires or switches to install.
- Rollover protection.
- Automotive style fill cap.
- Hold down brackets.
- Pressure and leak detection test.
- Clean and free of debris inside and outside of the tank.
Specifications:- Capacity - 41 Gallon.
- Dimension - 48 x 11 x 19 in.
- Item Weight - 52 lbs.
Price: 675.07
