FUEL SHOTZ AUX60WIKC 60 GAL DIESEL AUXILIARY TANK INSTALL KIT FOR GM TRUCKS THROUGH 2010
The wedge aluminum auxiliary tank is a perfect choice for flat beds and pickup with a 5th wheel. The tank slopes at a 45° angle on the tailgate side of the fuel tank for slightly lines and 5th wheel clearance. The tank provides multiple options for transporting and fueling purposes in regards to diesel fuel. Wedge style diamond plate aluminum diesel auxiliary tank with Fuel Shotz installation kit for GM trucks through 2010.
Features:- Quick easy installation.
- Tanks are baffled to reduce movement of contents.
- No wires or switches to install.
- Rollover protection.
- Automotive style fill cap.
- Hold down brackets.
- Pressure and leak detection test.
- Clean and free of debris inside and outside of the tank.
Specifications:- Capacity - 60 Gallon.
- Dimension - 56 x 20 x 18 in.
- Item Weight - 79 lbs.
Price: 886.23
