FUEL SHOTZ AUX65CBRIK 65 GAL AUX TANK TOOLBOX COMBO INSTALL KIT FOR FORD DODGE 2011-C GM
The rectangle aluminum auxiliary tank is the most popular ATI product. The tank and toolbox present a great combo that provides diesel storage along with the security of tools and equipment. Rectangle diamond plate aluminum diesel auxiliary tank and toolbox combo with Fuel Shotz installation kit for Ford Dodge and 2011-Current GM trucks.
Features:- Quick easy installation.
- Tanks are baffled to reduce movement of contents.
- No wires or switches to install.
- Rollover protection.
- Automotive style fill cap.
- Hold down brackets.
- Pressure and leak detection test.
- Clean and free of debris inside and outside of the tank.
- Fuel fittings separated from storage area.
- HD aluminum toolbox construction.
- Stainless locking handles.
- Lid opens a full 90 degrees for easy access.
- Lid suspended by automotive style gas springs.
- 3 layer rigid lid design for extreme use.
- Full aluminum piano hinge.
- Offset hinged area to allow for lid clearance.
Specifications:- Capacity - 30 Gallon.
- Dimension - 60 x 21 x 19 in.
- Item Weight - 96 lbs.
Price: 1199.03
