FUEL SHOTZ AUX66RIKC 66 GAL DIESEL AUXILIARY TANK INSTALL KIT FOR GM TRUCKS THROUGH 2010
The rectangle aluminum auxiliary tank is the most popular ATI product. The tank provides multiple options for transporting and fueling purposes in regards to diesel fuel. Rectangle diamond plate aluminum diesel auxiliary tank with Fuel Shotz installation kit for GM trucks through 2010.
Features:- Quick easy installation.
- Tanks are baffled to reduce movement of contents.
- No wires or switches to install.
- Rollover protection.
- Automotive style fill cap.
- Hold down brackets.
- Pressure and leak detection test.
- Clean and free of debris inside and outside of the tank.
Specifications:- Capacity - 66 Gallon.
- Dimension - 55 x 18 x 17 in.
- Item Weight - 77 lbs.
Price: 2996.96
