FUEL SHOTZ AUX80LIKC 80 GAL DIESEL AUXILIARY TANK INSTALL KIT FOR GM TRUCKS THROUGH 2010
The L-Shape aluminum auxiliary tank were designed to be used with an existing toolbox. The L-shape also allows for clearance in most 5th wheel applications. The tank provides multiple options for transporting and fueling purposes in regards to diesel fuel. L-shaped diamond plate aluminum diesel auxiliary tank with Fuel Shotz installation kit for GM trucks through 2010.
Features:- Quick easy installation.
- Tanks are baffled to reduce movement of contents.
- No wires or switches to install.
- Rollover protection.
- Automotive style fill cap.
- Hold down brackets.
- Pressure and leak detection test.
- Clean and free of debris inside and outside of the tank.
Specifications:- Capacity - 80 Gallon.
- Dimension - 48 x 28 x 26 in.
- Item Weight - 92 lbs.
Price: 837.05
