HOLLEY 121800 FUEL PUMP ELECTRIC - FEMALE O-RING
Features- Billet aluminum construction for durability and good looks
- O-ring inlet/outlet for high flow and superior sealing
- Excellent for use with carbureted or electronic fuel injection applications
- Fully submersible in tank for custom applications space savings and less plumbing
- Twin pump design allows the use of both pumps simultaneously or independently second pump can be activated on demand for power adders such as nitrous or boost
- Proven durability beyond 3000 hours in gasoline or diesel fuels
- Compact for easy installation on frame rails or other tight areas
Specification- Maximum pressure (psi) - 80 pounds per square in.
- Inlet attachment - Female o-ring
- Inlet quantity - Single
- Inlet size - -10 an
- Outlet attachment - Female o-ring
- Outlet quantity - Single
- Outlet size - -10 an
Price: 676.31
