MAGNA FUEL MGFMP-4303 PROTUNER 750 INLINE ELECTRIC FUEL PUMP REBUILD KITS
Features- Electric fuel pump rebuild and seal kits are designed to keep your fuel pump working properly
- The seal kits are composed of the exact same seals that went into your magnafuel pump when it was new
- The rebuild kits include the parts necessary to maintain optimum fuel flow and are of the highest quality
Specifications- Product Part: Fuel Pump Rebuild
- Fuel Type: Gasoline
- Inline: 750
- Weight: 7 lbs
Price: 877.85
