QUICK FUEL TECHNOLOGY QFT30-427 QFT 427 UPGRADED FUEL PUMP
Features- 427 GPH Flow25 PSI.
- Designed for drag race and other short duration competition; Supports from 800-2500 HP.
- Motor draws 11.7 Amps 25 PSI.
- 1/8 NPT Gauge Port.
- Highly efficient 6-vane design.
- Hard coat anodized billet aluminum housing.
- #10 AN Inlets and Outlets; #8 AN bypass port.
- Lower pump body is machined with a bearing pocket to receive the motor shaft bearing
- This significantly improves the shaft alignment reducing current draw and improving flow.
- The upper wear plate is integrated into the one-piece eccentric bushing for improved alignment and reduced friction.
- Compatible with all fuels (Gas Alcohol E85).
Price: 645.87
