TITAN FUEL 8020099 1999-2010 FORD FUEL TANK - 40 GAL.
Tank solves the problem of lining failure and corrosion in steel OEM tanks. Tank is light in weight corrosion-proof extremely durable and features a drain plug for easy maintenance. Complete with rollover vent valve. Fits in the place of the OEM stock tank.
Features- Military Grade Cross-Linked Polyethylene.
- Extra Heavy-Duty.
- Lightweight.
- Corrosion-Proof.
- Extremely Durable And Drain Plug For Easy Maintenance.
- Frame Mounted.
- Capacity - 40 Gallon.
- Fuel Type - Diesel.
- Material - Polyethylene.
Application- 1999-2010 Ford F-350 Super Duty.
- 1999-2010 Ford F-450 Super Duty.
- 1999-2010 Ford F-550 Super Duty.
Price: 1494.75
