TITAN FUEL 8020199 1997-2003 FORD FUEL TANK - 55 GAL.
55 Gallon extra heavy duty frame mounted after-axle replacement tank for Econoline diesel cut-away cab and chassis vehicles for model years 1999 to 2010. Tank is constructed of military grade cross-linked polyethylene (XLHDPE). Compatible with most bio-diesel fuel.
Features- Tank Solves The Problem Of Lining Failure And Corrosion In Steel OEM Tanks.
- Tank Is Light In Weight Corrosion-Proof Extremely Durable.
- Compatible With Most Bio-Diesel Fuel.
- Features A Drain Plug For Easy Maintenance.
- Capacity - 55 Gallon.
- Fuel Type - Diesel.
- Material - Polyethylene.
- With Shield - Yes.
Application- 2000-2002 Ford E-450 Econoline Super Duty.
- 2000-2002 Ford E-450 Econoline Super Duty Stripped.
- 2003-2010 Ford E-450 Super Duty.
- 2002-2002 Ford E-550 Econoline Super Duty.
- 2003-2003 Ford E-550 Super Duty.
- 1997-1999 Ford Econoline Super Duty.
Price: 1508.03
