TRANSFER FLOW TFL0800114225 TOYOTA TUNDRA FUEL TANK SYSTEMS
Features- Fuel tanks are made from 12-gauge aluminized steel for rust resistance and strength
- Fuel tanks are baffled to reduce fuel sloshing
- Fuel tanks mount inside the frame rail
- Powder coated black for a durable finish
- 46 gallon fuel tank hangs down one inch below the lowest part of the frame rail
Price: 2473.44
